dimae 16
I would like to share this Virtual Device for Android TV (Oreo 8.0) SONY Oled AG9. Maybe it is working for another TVs as well. If not, you just need to find the correct codes.
This VD was made from big help and examples of @StarkJohan so I was basically improving a little bit more his examples. @Fodder1 was also looking for this solution. I have tried to make this VD as complete as my original Sony remote.
1st) you need to know IP address of your TV: Home > Settings > Network > Advanced settings > Network status IP address
2nd) you need to enable remote connection here: Home > Settings > Home network > setup IP control > enable "Authentication Normal and PreShared Key (PSK). Set “0000" in this trial.
If you need your TV codes you can get it using terminal console. Follow this commands
and execute ./print_ircc_codes.sh SONYTV_IPThat's all
I hope it helps,
Thanks,
Edited by dimae24 answers to this question
