Hi there,
I'm running a heat controller on fw 4.3 with a issue (running on a non-fibaro controller). When installed on a valve with the RA-N adapter the controller stays in a open position, turning the knob to white doesn't do anything and calibration closes the valve for a second and than open again. After the calibration the controller still don't close.
I tried to install the controller on a other valve (one without the need for a adapter) and the controller works perfectly.
Hope somebody can help me to figure this out.
Cheers Alexander
Faulty adapter?
Try this adapter on a other device?
Connect adapter on Fibaro and see if its working also with counter force on it.
Succes
    Hi Sjakie,
    Tried to apply some pressure to the knob and this seems to work. Fingers crossed that's it keeps working! :-)
    Cheers, Alexander
    Does the heat controller only rely on the internal temperature sensor (of if bought the external bluetooth sensor)? Or is it possible to send temperature data from a other sensor?
    To make my question more clear: I have my radiator under a windowsill and noticed that the Fibaro heat controller doesn't respond as it should.  Is there a internal temperature sensor that the controller rely on? Or is it possible to have temperature data from my zwave network to control the heat controller?
    Edited by boogie1982
    additional information
