rollershutter 3 with relais
I try to use a Fibaro 3 to move in and out a lineair actuator
This is a DC actuator, so I have to  reverse the poles using 2 relays.
When I connect the FGR223 to sent "up signal" to one relais and "down signal" to the other relais
1, It does not hold the connections up and down , but it disconnect after a few seconds
2, When I want to operate via Homey controller:
    -  Mij Homey controller does not show a "up or down" button and by pushing, nothing happens
    -  It only works via : dim niveau" and then....
    -  only the Q1 makes the tempory connection
3, I cannot find a setting to change this
Is ther somebody who can help me?
thanks
Lee,
Link to post
  • 3 months later...
Which exact relays are You using? Chain linking two or more relays always gives up unpredicted ersults. Try using sonoff wireless
Link to post
