Showing results for tags 'rollershutter 3'.
I try to use a Fibaro 3 to move in and out a lineair actuator This is a DC actuator, so I have to reverse the poles using 2 relays. When I connect the FGR223 to sent "up signal" to one relais and "down signal" to the other relais 1, It does not hold the connections up and down , but it disconnect after a few seconds 2, When I want to operate via Homey controller: - Mij Homey controller does not show a "up or down" button and by pushing, nothing happens - It only works via : dim niveau" and then.... - only the Q1 makes the tempory connection
Hello everybody, how should I configure the HC2, so that when the alarm system is armed and a motion is detected, all roller shutters go up. In the alarm control can only be specified that all should go down. What really does not recommend security service here in Germany. Does anyone have a solution for me? I use the HC2 with the latest firmware and the Rollershutter 3 with the latest firmware. Many thanks in advance.
- 1 reply
- hc2
- rollershutter 3
(and 4 more)
