Showing results for tags 'motion detection'.
Found 3 results
  1. Is there a possibility that the device records upon motion detection - similar to the possibilities of the Ring Doorbell?
  2. Hello everybody, how should I configure the HC2, so that when the alarm system is armed and a motion is detected, all roller shutters go up. In the alarm control can only be specified that all should go down. What really does not recommend security service here in Germany. Does anyone have a solution for me? I use the HC2 with the latest firmware and the Rollershutter 3 with the latest firmware. Many thanks in advance.
  3. it's possible to integrate HC2 with an ip-camera by specifying URL:s for the video stream and controlling it with left/right/up/down URL:s etc. This is one-way communication from HC2 to the camera. Now, some cameras can be armed/disarmed, which means that it will start to record when it detects motion. The idea is that this should trigger an alarm in HC2. My idea is to have a scene which can arm/disarm the camera and then, when the camera detects motions it should trigger a scene in HC2. Has anyone figured out how to trigger a scene in HC2 when the camera detects motion
