Hello ;
My fibaro HCL seem to be freezing and icon are no longer showing their pages when i click on them. Please check attached image
Your Help is really aprreciated
Hi
Try deleting your browser cache, possibly restarting your computer and / or HCL.
    Hello
    I deleted the cash and restardtd the HCL also the computer and it doesn't help ... ?
    Now the icon are clickable for example when i go to configuration and click on it .. i see nothing and the dashbaord deosn't change and still blocked on the main dahsbiard!
    Is there any solution for this new HCL
    Your help is really appreciated
    any one can help with my issue?
    @DomoAutomation  did you try a different browser?
    Disconnect the HCL from the powerline.
    wait for 5 minutes.
    Power on again.
    Make sure you're browser cache is empty. Or use privat tab.
    If this doesn't do the trick you have to follow the manual for recovery mode.
    Hopefully you have a back-up
    I've done that it's not working either
    even after recovery its not working
    is there any other solution §?
    Try another web browser.
    the same issue even with firefox
    is there any other solution ?
    thank you all i've done a recovery and the problem is resolved ..
    The last question is the controller is asking me update    to  4.530   is this new upadte worthy to go for or it's not recomanded that i go for this version
    Hi
    Good thing you made it work.
    You can easily update it to 4,530
    Once you've done that, you'll probably be asked for update 4,570
    It works fine with 74 scenes and 28 devices with me.
    It is a must to delete historical power measurements once in a while.?
    Same here,
    Also running 4.570 without any problems
    After update to 4.530 make backup first. before you update to 4.570
    uncheck the question "Back-Up before upgrade"
    IMHO. Make manual back-ups only.
    Edited by Flash
    @hTiger1
    do you use  74 scenes and 28 devices    with HCL or HC2 ?
    I guess its not string enought to run the HCL to run 74 scences and 28 devices normally you should use a HC2 which is faster and stronger
    so what do you think?
    Hi
    I run with HCL.
    Fibaro has now managed the software so that HCL no longer freezes.
    It does the job really well, but I want hat, so I'm waiting for HC3.
    When I bought HCL I only had 4 danfoss thermostats, but this automation is quite addictive, so I now have 28 units.?
