marcin12 0
I have a problem with Dimmer 2 (v3.5) configuration.
This is the only module that I try to connect to a 2-wire installation, the rest Dimmer 2 are connected with neutral wire (3-wire) installation and I have no problem with them.
This Dimmer is intended to control a fluorescent lamp (approx. 30W; this is standard fluorescent lamp, not LED one), currently it is properly controlled by the Qubino Flush module (installed next to the lamp, so with neutral). Now I wanted to move the module to the box at the wall switch, that is why I try to use Dimmer 2.
During all tests I set parameter 32 to 0 (dimming now allowed)
I run calibration using B-button and I get such results:
Any help with this will be appreciated.
I assume that I need to tune somehow parameters after auto configurations is completed, but since I don't fully understand what some params mean I don't want to damage my lamp or the Dimmer module.
