HC3 and HUE
Guest kallecux
Guest kallecux
Hi there!
The first time I played with the HC3 I encountered the following errors:
- Although Philips Hue lamp was given as the category "lighting", it does not appear as lighting in the app.
- Furthermore a 404 error appears when calling the advanced settings of the Hue lamp
Greetings!
It is simply because Fibaro did not revise the manure, but took it over from the HC2.
The same crap as with the SONOS panel.
The forum with your virtual devices shows that things are going better.
Unfortunately, I do not yet know how to insert them into the HC3.
