HC3 and LUA-Editor
Guest kallecux
Guest kallecux
Is there a way - similar to the HC2 - to see the device IDs, properties, etc. while working in the LUA Editor?
1 minute ago, Macschimmi said:
Open a 2 browser window or tab.
One page device list, other LUA
Device list doesn't show properties of the devices, only ID and name (room name)
Properties means: value, power, energy, batteryLevel and etc.
In addition you cannot see available actions for device, like turnOn, setLevel, setColor and etc.
You can see that only in block scene when you choose specific device.
we are working on it
Very happy with that answer, I just got the hc3 and mis that function in the lua editor
Got my new HC3, like to experiment with it. So I make a simple scene. Using Block scene. Motion detection set wall powerplug on and after 60 secs turn wall powerplug off.
This works. Now i want to translate that to LUA. press button to Lua.
When the LUA scene is running it is not working.
In LUA code i see now that ID-number  of motion sensor and wall powerplug are not correct added by 1.
When I change to the correct ID number still the scene is not working.
Can anyone explain me what is going wrong ??
@RobS
and did you changed the scene from "Manual" to "Auto" after you copied it to lua? By default every converted/copied scene is set to manual, so it will not trigger
/monthly_2020_02/image.png.2a96b8d033196f45c0d5a53e2d7b79c9.png" />
Edited by tinman
Is there another source of this information in this moment please? This data are crucial for Lua programmers i think.
You can find all latest information at
Edited by cag014
Thanks. But i need some source of available device properties and actions like in HC2.
You have two options to find device properties and actions
1. using API    use link  http://<HC-IP>/api/devices/<devID>
2. Create demo block scene and use wanted device as trigger to see list of available properties.
Guest rafal_ll
  • W dniu 7.03.2020 o 23:10, cag014 napisał:
    Masz dwie opcje, aby znaleźć właściwości urządzenia i działania
    1. używając API użyj linku http: // <HC-IP> / api / devices / <devID>
    2. Utwórz scenę bloku demonstracyjnego i użyj żądanego urządzenia jako wyzwalacza, aby zobaczyć listę dostępnych właściwości.
    Sorry, the question is out of place. where do you get the hc3 dark interface from?
    credit goes to  @jakub.jezek
    execute below in command window.
    curl -X PUT "http://<user>:<passwd>@<HC3-IP>/api/users/2"  -H "Content-Type: application/json" -d "{\"skin\":\"dark\"}"
    This for admin user.
    For any other user, change /api/users/<user-ID>
    Logout and login to change the skin
    Edited by cag014
    \"skin\":\"dark\"
    the last time i worked with dark mode, my user profile got f* up after update, haven't tried anymore with current Version, as it is disabled by Default, probably by reason, but who know ^^
    Meanwhile works fine... two days in a row...
    Interesting. So far good in my case. Although is is not finished, I still wanted to check it out. And I remember that you shared some screenshot of it. So I went poking around.
