HC3 and events
Guest kallecux
Guest kallecux
I hope that I can trigger a scene if I generate an event in another scene.
Scene 1:
fibaro.emitCustomEvent("testevent")
Scene 2 DECLARATION:
  conditions = { {
      isTrigger = true,
      operator = "==",
      property = "testevent",
      type = "custem-event"
  operator = "any"
but, when i send the event "testevent" scene 2 is not startet.
Greetings!
Karl Heinz
6 answers to this question
Scene 1:
  conditions = { {
      isTrigger = true,
      operator = "==",
  operator = "any"
Greetings!
Karl Heinz
Haven’t tried but should it be ’custom-event’ instead of ‘custem-event’ ?
And you have defined the event prior?
Guest kallecux
    :-) - i took the code from the documentation:
    Quote
    Custom events
    For custom events, the interpretation of conditions fields is as follows:
    type – takes value "custem-event".
    property – name of the custom event (text).
    isTrigger – takes value true.
    but i did not work, if i change it to "custom-event".
    I thought, that the definition is the DECLARATION....where is it to define?
    One of the panels, or do api.post("/customEvents",{name=<name>,userDescription=<descr>})
    Guest kallecux
    Thank you - it works!!
    try something else
    it does works here
    Edited by tinman
    Guest kallecux
    Yes i found the definition in the frontend and it works.
    Greeting!
