[SOLVED ] Unable to upload icons
Hello
I tried to upload the attached icons, after choosing the files when I press "Add" the interface go black with blue rolling balls and then back.
The icons are not uploaded and the files fields are empty ...
No error message
Note that some other Icons are uploaded
Any help welcome
Thank you
The reason may be that the image has wrong size. It should be 128x128 pixels.
Also, you must be connected locally to your HC with your local IP.
    120x120 pixels .... it failed
    128x128 pixels ..... SUCCEED
    Thank You !!!
