HC3 Block scene sunrise/sunset not working?
Whenever I drag the block "Sunrise & Sunset" to the left "All of these are true" block, the "Save" function for the scene turns grey.
In the right block "Do the following", I have just put a single Hue lamp to "Turn on". All fields in all blocks are filled out - so no empty options that hinder saving. If I put another trigger, like an "Exact time" - it works and I can save. But whenever I put the "Sunrise & Sunset" trigger in, the Save function turns grey.
The clock in the HC3 runs correctly. Anyone have the same issue?
Cheers,
4 answers to this question
Try 1 minute later after sunrise, that will work - it seems that there are still errors in the system
    If I used the "Sunrise & Sunset" block, but changed it to set X minutes after or before sunset, and joggled between the settings, I could set AT sunset finally.
    But if I used a "new" "Sunrise & Sunset" block without having joggled between settings, it could not be set AT sunrise or sunset. Clearly a bug.
    yes it is, it has been already reported and will be fixed in next firmware release, coming in few days
    I still have that bug.
    i tried to do something 15 min after sunset but it is not saved.
    When i open the blockscene again i see 24 h after sunset.
