Hi guys I ask for Lua scene to control the lights automatically into star's by motion detection bt problem not for that
The problem is I want that scene work between 6 pm to 7am and if motion detection don't detect any move then turn off light after 20 minutes
Any one hare can help my to do that
 And Thanks for every one
You can do it with
and many other actions... you can find an examples how to use it in
Here is the solution for you:
The light will turn off if no motion detected within 20-25 minutes.
Edited by cag014
    Thank you, I will try now
    %% autostart
    %% properties
    %% events
    %% globals
    jS2n={stairMS=110,stairSoptLight=266,stairHiddenLight=263} --please change stairMS and stairLight to your real device ID
    jM = {{
    {5,"stairMS",{state="value=true",timeSlot="18:00~07:00",timeSpanOn=true,
    trueAct={"stairSoptLight","stairHiddenLight","turnOn","",""},
    timeLoopAct={"stairSoptLight","stairHiddenLigh","turnOff","","",
    {"stairMS:valueModified>1200|stairSoptLight,stairHiddenLigh:value=true"}}}
    Edited by mohamedsalah
    What is wrong now?
    Please pay attention that any device name should be within back apostrophe ` (located on same key with ~)
    Edited by cag014
    Very thanks for your help
    put The same problem ??
    Hope it works for you now...
    put that still not work ??
    I have edited the post probably after you have saw it...
    Edited by cag014
    it work now
    i am Very thanks for your help??
    You are welcome.
    What's defrant between that scene
    %% autostart
    %% properties
    110 value
    266 value
    263 value
    %% events
    %% globals
    jM = {
    {5,"`stairMS`",{state="value=true",timeSlot="17:00~07:00",timeSpanOn=true,
    trueAct={"`stairSoptLight`|`stairHiddenLight`","turnOn",""},
    timeLoopAct={"`stairSoptLight`|`stairHiddenLigh`","turnOff","","{`stairMS`:valueModified>1200|`stairSoptLight`,`stairHiddenLigh`:value=true}"}}},
    And that scene
    %% autostart
    %% properties
    110 value
    %% weather
    %% events
    %% globals
    local sourceTrigger = fibaro:getSourceTrigger();
    function tempFunc()
    if (
     ( tonumber(fibaro:getValue(110, "value")) > 0  and  (math.floor(os.time()/60)-math.floor(1582381980/60))%60 == 0 )
    then
        fibaro:call(263, "turnOn");
        fibaro:call(266, "turnOn");
    setTimeout(tempFunc, 60*1000)
    if (sourceTrigger["type"] == "autostart") then
    tempFunc()
    else
    if (
     ( tonumber(fibaro:getValue(110, "value")) > 0  and  true )
    or
    then
    The images for scend scene
    The target for the first one is make light on if motion detection detact any move from 17 pm to 7 am and if no motion after 20 minutes the light it will be off but the code is run success but light don't work
    Scand scene light work but all the time in day
    Wath should I do to solve this problem problem ??
    Do you mean that lights don't turned ON?
    What exactly doesn't work?
    Regarding block scene: Looks OK, but you need to create another block scene that turns lights off when sensor back to safe
    Edited by cag014
    In frist scene the light don't worke
    In the second scene the light work but all time
    In first scene the light don't turn ON?
    Are you sure it work at all or shows an error?
    The reason to my question is that you have typo error
    jM = {
    instead stairHiddenLigh it should be stairHiddenLight. Missing 't'
    Wall i will try that
    Regarding block scene: Looks OK, but you need to create another block scene that turns lights off when sensor back to safe. It should be a same scene. Replace Breached to Safe,  TurnON to TurnOff and set 1200 s
    Edited by cag014
