Heating problem
hi,
Step by step:
1. Add device Fibaro double switch connected to 2x Solenoid
2. Add device Fibaro UBS + DS18B20 as Thermometer
3. Add device  -> Thermostat
4. In thermostat set temperature sensor and heating device
5. Add climate Zone
6. Set Heating plan
Problem:
Double switch not startet if temperature is lower than the set temperature.
This scenario working in HC2...
6 answers to this question
i have the same problem. i now made a 2 rule's to turn on/off heating or else it would be cold in my house.
i am getting annoyed with the hc3 noting is working.
    i dont know why but not it working... but other zone - not working...
    Megic from Fibaro...
    I have also try linked devices Thermostat, a few days ago. After linked temperature sensor and wallplug switch together then I set up Climate Zone similar as you above. Nothing was happening, the wallplug was still off when it should be on.
    So I tried the very first thing which came through my mind and that was reboot HC3 and after that it worked as it should. But maybe this is not your case, it may worth a try.
    Did you try to control your Climate Zone via mobile app? Does it work or not at all?
    Hope you will be lucky.
    is crazy but if i set temperature in mobile App - it's working. When i set in computer - is not working.
    Restart Fibaro after setup Climate Zone. Work for me after restart.
    Have You tried to restart/reboot HC3 after setting temperature? I mean when you set temperature in PC web browser you are setting this temperature for some time period, sync can took some while or it can sync at the closest temperature setpoint in Heating plan .
    Edited by SmarterHOME
