Berges01 0
Hi there
After I had registered about 40 devices and created about 8 climate plans, I did a Bachup on the HC3.
The HC3 then started properly (after finishing the backup).
Then I created about 30 simple scenes with:
If door open or window on heating plan Manal to 8 ° C.
If door and window close Activate heating plan.
Then a backup was created this time on the cloud and it seemed to have worked out.
Then the system started and now hangs with the screen:
/monthly_2020_02/image.png.eaaaf104d5b2bcd89df998dacb8c127c.png" />The same is true yesterday.
I started in recovery mode and played back the backup
with the same result.
Even an older Bachup didn't work and showed that it behaved the same way.
Then I made a factory reset out of despair and started again.
Now the same thing!
HELP !!
