BachelorBoysa 0
Hello, I've been trying to use the REST API to make my own application and in order for this to work I'm heavily dependant on the Serial Number which each Fibaro sensor has.
The problem is that Fibaro doesn't seem to have any Fibaro Sensor which also measure the Humidity. So I have bought a Cleverio Humidity sensor (
) but the problem is that in the REST Api it isn't provided a serial number under the "properties". I am also not able to edit these "properties" in the api.I then bought a Netatmo weather station, but the problem is the same here, no serial number.
My question is, do anyone know of a Humidity sensor from Fibaro or a 3rd party humidity sensor which I can connect to my Home Center 2 which contains a serial number?
