Powerview (luxaflex) often loses its connection
Powerview silhouette is better than hc2 but it also doesn't work 100% in hc3.
if the connection is gone, rebooting helps again for 1 or 2 days
in hc2 I had to provide each lua script with the correct code again
Edited by bonlite
I'm seeing the same thing in HC3 with powerview QA.
Are you running scenes in powerview mobileapp as well as in fibaro?
I’m using powerview hub in combination with hc2 to control 21 blinds, no problems and no need to reboot every few days.
however, I did have a lot of problems with the powerview plugin for hc2, I decided not to use the plugin any longer, but control the powerview hub directly with http from a virtual device with lua statements, since then, system running flawlessly for two years now
