HC3 and iTach IR?
I'm asking for help here regarding getting iTach to work with HC3 via an QuickApp.
In HC2 it was easy, we did it like this:
@Sankotronic posted LUA code for a HC2 VD a little while ago, maybe a good HC3 QA-coder can help getting it to work? Grateful for any help!
Link below to @Sankotronic VD.
12 answers to this question
on the end part of quick apps you got example
TCP connection sample (for devices like Global Caché)
    Wonderful, thank's! :) I will test when I get back home this afternoon!
    Edit: Yes, it works! I changed IP-adress and Port number in the Variables section of the QA, then I entered this in a button:
    self:send("sendir,1:3,1,37878,1,1,340,169,22,21,22,63,22,21,22,21,22,63,22,21,22,63,22,63,22,21,22,21,22,63,22,63,22,21,22,63,22,63,22,21,22,63,22,63,22,21,22,63,22,21,22,21,22,63,22,63,22,21,22,21,22,63,22,21,22,63,22,63,22,21,22,21,22,1500,340,84,22,3631,340,84,22,37000x0D0x0A", true)
    Remember to add "0x0D0x0A" in the end of the IR code, and also add ", true" after the IR code.
    Edited by robw
    Updated info.
    Hello!
    Can you share your example? I want to add a similar IR device
    On 4/19/2020 at 2:05 AM, antoniopll said:
    Hello!
    I ended up with adding functions to the main code that refer to a button. So, in the end of the code A. Socha refers to, add a function. In the below example it is a power button for a BD player:
    function QuickApp:uibtn_Power_1OnReleased(event)
    self:send("sendir,1:3,23,37537,1,1,171,169,20,18,20,18,20,18,20,18,20,18,20,55,20,18,20,18,20,18,20,18,20,18,20,18,20,18,20,18,20,18,20,18,20,169,20,55,20,55,20,55,20,18,20,18,20,18,20,18,20,18,20,18,20,18,20,18,20,18,20,55,20,55,20,55,20,55,20,55,20,55,20,55,20,55,20,37000x0D0x0A"true)
    Then make a button,
    onReleased: uibtn_Power_1OnReleased
    Hello
    I'm trying to get this to work but am having no joy. The Itach works from my old Vera controller so I know I have the Ip and port correct but I'm not a coder and am confused what the on and off buttons are for ? I have added the function above but with a IR string that I now works with vera but no joy any help would be great thanks
    3 hours ago, Dacron said:
    Hello
    see attachment for a Samsung TV. I combine the On / Off button and tested on my HC3.
    Works perfect.
    ps; for other IR devices, you must changer de HEX codes (
    Thanks twanve you are a gentleman !!
    Sorry but I still can't get this to work. I have the unit working with my VERA which I'm moving away from so I know the ip 192.168.1.38 is correct, the port 4998 and the HEX code sendir,1:1,1,37914,1,1,342,170,22,21,22,21,22,63,22,21,22,21,22,21,22,21,22,21,22,63,22,63,22,21,22,63,22,63,22,63,22,63,22,63,22,21,22,21,22,21,22,63,22,21,22,21,22,21,22,21,22,63,22,63,22,63,22,21,22,63,22,63,22,63,22,63,22,1538,\r
    works to turn my TV on/off. I have tried ,0x0D0x0A after 1538 as well as the below function. I haven't altered the code at all other than the IP, Port and the first function to the one below. Thanks
    function QuickApp:buttonOnOffOnReleased(event)
    self:send("sendir,1:1,1,37914,1,1,342,170,22,21,22,21,22,63,22,21,22,21,22,21,22,21,22,21,22,63,22,63,22,21,22,63,22,63,22,63,22,63,22,63,22,21,22,21,22,21,22,63,22,21,22,21,22,21,22,21,22,63,22,63,22,63,22,21,22,63,22,63,22,63,22,63,22,1538x0D0x0A",true)
    Here is a snippet from the code for my reciever:
    function QuickApp:uibtn_PowerOnReleased(event)
    self:send("sendir,1:1,1,37878,1,1,340,169,22,21,22,63,22,21,22,21,22,63,22,21,22,63,22,63,22,21,22,21,22,63,22,63,22,21,22,63,22,63,22,21,22,63,22,63,22,21,22,63,22,21,22,21,22,63,22,63,22,21,22,21,22,63,22,21,22,63,22,63,22,21,22,21,22,1500,340,84,22,3633,340,84,22,3633,340,84,22,3633,340,84,22,3633,340,84,22,37000x0D0x0A"true)
    Have you named the button itself correctly? In my example above, the name in the "onReleased" text field up in the right has the text "uibtn_PowerOnReleased". I've also set the ID of the button to "btn_Power", and the label to "Power".
    All the functions of the buttons I put last in the code, after:
    function QuickApp:onInit()
        self:debug("onInit")
        self.ip = self:getVariable("ip")
        self.port = tonumber(self:getVariable("port"))
        self.sock = net.TCPSocket()
    Which itach unit are you using robw ? I have the Wi Fi connected Flex units.
    I didn't change your buttons at all, I changed the IR command string only in your first function and entered the IP and port of the device. If I use iTest the IR emitter blinks but if I try any of the buttons in test mode in HC3 the emitter doesn't blink. I know the buttons all work for you so I would expect the IR emitter to blink on my unit but nothing.
    Thanks robw, I've finally figured what I was doing wrong ! I was putting the ip and port numbers in the code and not changing it in the Variables tab. Lesson learnt and all works perfectly.
    Glad it work for you now! :)
