As has been re-iterated many many times on this forum, there are two methods of updating a slider in a virtual device from a scene or another VD:
  1. Using fibaro:call(device, "setProperty", "ui.sliderX,value", value) causes the numerical value of the slider to be updated, but not the length of the slider bar. Neither does it execute the code behind the slider.
  2. Using fibaro:call(device, "setSlider", X, value) causes the numerical value and the length of the slider to be updated,, and executes the code behind the slider.
In both cases, "device" is the ID number of the VD,  "X" is the slider reverence number and "value" is the new slider value (0-100). Generall, option 2 is preferred because everything is updated. However, there seems to be an issue if the VD has more that nine sliders. Executing a few lines of test code for each of the methods illustrates this.
First, method 1. Executing this code:
local device = fibaro:getSelfId()
local sliderString1
local sliderString2
local numSliders = 13
fibaro:debug('-----------------------------------------------------------')
fibaro:debug('--Set Sliders----------------------------------------------')
for i = 1, numSliders do
    sliderString1 = ('ui.Slider' .. tostring(i) .. '.value')
    fibaro:call(device, "setProperty", sliderString1, tostring(i))
       fibaro:debug('Slider ' .. tostring(i) .. ' = ' .. tostring(i))
fibaro:debug('--Read Sliders---------------------------------------------')
    sliderString2 = fibaro:getValue(device, sliderString1)
    fibaro:debug(device .. ', ' .. sliderString1 .. ' = ' .. sliderString2)
Gives:
[DEBUG] 16:21:04: --Set Sliders----------------------------------------------
[DEBUG] 16:21:04: Slider 1 = 1
[DEBUG] 16:21:05: Slider 2 = 2
[DEBUG] 16:21:05: Slider 3 = 3
[DEBUG] 16:21:05: Slider 4 = 4
[DEBUG] 16:21:05: Slider 5 = 5
[DEBUG] 16:21:05: Slider 6 = 6
[DEBUG] 16:21:05: Slider 7 = 7
[DEBUG] 16:21:05: Slider 8 = 8
[DEBUG] 16:21:05: Slider 9 = 9
[DEBUG] 16:21:05: Slider 10 = 10
[DEBUG] 16:21:05: Slider 11 = 11
[DEBUG] 16:21:05: Slider 12 = 12
[DEBUG] 16:21:05: Slider 13 = 13
[DEBUG] 16:21:05: --Read Sliders---------------------------------------------
[DEBUG] 16:21:05: 1044, ui.Slider1.value = 1
[DEBUG] 16:21:05: 1044, ui.Slider2.value = 2
[DEBUG] 16:21:05: 1044, ui.Slider3.value = 3
[DEBUG] 16:21:05: 1044, ui.Slider4.value = 4
[DEBUG] 16:21:05: 1044, ui.Slider5.value = 5
[DEBUG] 16:21:05: 1044, ui.Slider6.value = 6
[DEBUG] 16:21:05: 1044, ui.Slider7.value = 7
[DEBUG] 16:21:05: 1044, ui.Slider8.value = 8
[DEBUG] 16:21:05: 1044, ui.Slider9.value = 9
[DEBUG] 16:21:05: 1044, ui.Slider10.value = 10
[DEBUG] 16:21:05: 1044, ui.Slider11.value = 11
[DEBUG] 16:21:05: 1044, ui.Slider12.value = 12
[DEBUG] 16:21:05: 1044, ui.Slider13.value = 13
As would be expected. However executing a code snippet using method 2, like this:
local sliderString1
local sliderString2
      fibaro:call(device, "setSlider", tostring(i), tostring(i))
Give this:
[DEBUG] 16:43:02: --Set Sliders----------------------------------------------
[DEBUG] 16:43:02: Slider 1 = 1
[DEBUG] 16:43:02: Slider 2 = 2
[DEBUG] 16:43:02: Slider 3 = 3
[DEBUG] 16:43:02: Slider 4 = 4
[DEBUG] 16:43:02: Slider 5 = 5
[DEBUG] 16:43:02: Slider 6 = 6
[DEBUG] 16:43:02: Slider 7 = 7
[DEBUG] 16:43:02: Slider 8 = 8
[DEBUG] 16:43:02: Slider 9 = 9
[DEBUG] 16:43:03: Slider 10 = 10
[DEBUG] 16:43:03: Slider 11 = 11
[DEBUG] 16:43:04: Slider 12 = 12
[DEBUG] 16:43:04: Slider 13 = 13
[DEBUG] 16:43:04: --Read Sliders---------------------------------------------
[DEBUG] 16:43:04: 1044, ui.Slider1.value = 10
[DEBUG] 16:43:04: 1044, ui.Slider2.value = 11
[DEBUG] 16:43:04: 1044, ui.Slider3.value = 12
[DEBUG] 16:43:04: 1044, ui.Slider4.value = 13
[DEBUG] 16:43:04: 1044, ui.Slider5.value = 5
[DEBUG] 16:43:04: 1044, ui.Slider6.value = 6
[DEBUG] 16:43:04: 1044, ui.Slider7.value = 7
[DEBUG] 16:43:04: 1044, ui.Slider8.value = 8
[DEBUG] 16:43:04: 1044, ui.Slider9.value = 9
[DEBUG] 16:43:04: 1044, ui.Slider10.value = 10
[DEBUG] 16:43:04: 1044, ui.Slider11.value = 11
[DEBUG] 16:43:04: 1044, ui.Slider12.value = 12
[DEBUG] 16:43:04: 1044, ui.Slider13.value = 13
Which is clearly wrong. Is this a bug, or have I done something really dumb (if so please enlighten me). If it is a bug, does a workaround exist?
TIA.
I also observe a problem with the slider, even in the second one in the VD.
By the second method I cannot update the value to Slider by issueing the small code under the VD button.
