Speedo67 1
i have included a FGS-223 and configured as momentary switch (S1) and as a scene controller (S2).
For a few days it works very well, but then there is no reaction for the scene-controller, because the local switch (S2) - status doesn’t report to HC2.
The same for S1 – the light goes on but on UI and App there is no status-change. In the other direction (UI / App- switch on/off) – the FGS223 reacted.
I see on sniffer (@tinman ) that the signal is going out and the receive is ok.
Here on Fibaro Forum there are posts that say change parameter 20 from 2 – 0 – 2 will fix that issue.
I try, but the modification will not be executed. (see attached pictures).
I take a ticket an Fibaro support (202307) and get this answer:
..We’re aware of this issue and we’ve already forwarded it to our engineers, who are currently working on resolving it as soon as possible. I’m very sorry for the inconvenience it caused but I have to ask you for a little more patience.
Has anyone a idea or way to fix this issue? I suspect Fibaro engineers are very busy on HC3-progress, so that problem will be fixed at very later date...
/monthly_2020_03/picture_1.JPG.4f9c42115c9254096a6d4162bf9edc6c.JPG" />Please login or register to see this attachment.
5 answers to this question
