Incomplette 0
Hi, i add Aeotec multisensor 6 to my HC3 but it seems not working properly. I try to add and remove 3 times. After installation "wake up interval" is set to 0s and i cant change it.
Automatic updates working only for PIR sensor. Temperature, luminance, humidity, uv is not auto updated at all (now for almost 10 hours). I setup thresholds to low values and manual wake up device to sync this settings. Nothing help ...
Even threshold for temperature is impossible to change to normal value (eg. 1C). Default value after installation is set to 131097.6 C and after change and sync is always reset to this value.
Have someone similar issues with Aeotec multisensor 6? It is device or hc3 related problem?
20 answers to this question
