Showing results for tags 'aeotec multisensor 6'.
Found 3 results
  1. Hi, i add Aeotec multisensor 6 to my HC3 but it seems not working properly. I try to add and remove 3 times. After installation "wake up interval" is set to 0s and i cant change it. Automatic updates working only for PIR sensor. Temperature, luminance, humidity, uv is not auto updated at all (now for almost 10 hours). I setup thresholds to low values and manual wake up device to sync this settings. Nothing help ... Even threshold for temperature is impossible to change to normal value (eg. 1C). Default value after installation is set to 131097.6 C and after change and sync is always reset to this value. Have someone similar issues with Aeotec multisensor 6? It is device or hc3 related problem?
  2. After adding Aeotec multisensor 6 to the HC3 the HC3 recognizes the Aetec MS6. The MS6 does not send any values. All remains at 0. HC3 does come up with a template for the parameters however changing the parameters is impossible, they remain at 0. Thanks, Willem Bousema Switching from HC2 to HC3
  3. HI, I am trying to register Aeotec MultiSensor 6 on Fibaro Home Center 2 (v 4.056). After registration is complete I can see temperature, light, humidity sensors but no motion or vibration sensor. Is there any specific configuration I need to load for it? Also the temperature, light, humidity sensors doesn't seem to show correct values ( most of them shows 0 value) Thanks & Regards, Kamal
