Multichannel association HC3
Mads
When an association is set in the lifeline association group, and it is a multichannel association (HC3 self-detect whether it is a multi-channel or a single-channel association), then the multi-channel-association-set command only contains a node id (not a node id and an endpoint), and therefore the command is handled as a single-channel-association-set command by the device, so the association does not work for the endpoints and it is not possible for HC3 to see from which endpoint the status report came from. Will it not be possible for HC3 to use the same command as HC2 is using, when setting multi-channel associations?
