Set Fibaro Alarm On or Off through Virtual device
mbnn
Hello all,
Does anyone happen to know how to set a fibaro alarm (Zone) to on or off with a quick app/vd? :)
Through the blocks does not work.
Edit, fixed this as follows:
- Create a virtual device in HC3 called Alarm , with 2 buttons and the following code:
Make sure you replace XXXXXX with the device ID of the alarm Zone you want to arm or disarm. (you can find this by going to http://ipofyourhc3/api/devices)
- After that, When you press this virtual device it will arm the alarm (satel or whatever you have assigned in HC3 as alarm)
Edited by mbnn
I had a similar situation this is how I have fixed it
   I am reading json via http from an ESP8266 status of garage door and on same phisycal device a relay module ... quite cheap devices
 I wanted to have alarm sensor and push button to open the gate so I used the following :
    1 . quick app type binary switch ( can be also door lock with other functions calls )
if (previousValue~= newReadValue then
                 previousValue = newReadValue  <--- this is to avoid flip o value or update if not needed ( also to avoid debugging a lot for the turn on / off of deviceIDGarageDoorssensor)
if readturnON then
                      self:updateProperty("value"true)
                      fibaro.call(deviceIDGarageDoorssensor,"turnOn")   <--- I do this in order not to read again status from ESP
                    else
                        self:updateProperty("value"false)
                         fibaro.call(deviceIDGarageDoorssensor,"turnOff")
    2. quick app with door sensor to be included in alarm zones
function QuickApp:turnOn()
function QuickApp:turnOff()
function QuickApp:onInit()
    --self:debug("onInit")
Edited by vifefref45
