HC3 and parameters
Guest kallecux
Guest kallecux
I despair - I try to change the parameters of a device via Lua but I get a 401 - access denied feedback.
Why? Does anyone have a tip for me. Thank you!
[DEBUG] 07.03.2020 16:34:05: onInit
[DEBUG] 07.03.2020 16:34:06: Error: 401 - Zugriff verweigert
This is my code:
Greetings
Karl Heinz
P.S:
I tried different variants of the closing brackets because the template I found was inconclusive. But without success. "}]}}" respectively "}}]}"
Edited by kallecux
4 answers to this question
This is my code:
With httpclient you need to authorize. Use api.put()
Guest kallecux
    Hi @jgab thank you for the hint, if i go this way i get response 400.
    is the data structure wrong?
    Greetings!
    Greetings!
    Haven't tested this (isn't it risks to set parameter like this?) but this "more" correct. - need to send the data payload as second argument to api.put,
    Guest kallecux
    @jgab Yes you are right it works - i think it is better to convert der parameter with json.encode - thank you very much!!
    I played with the swagger function - it is very helpful!
    You say:
    Quote
    Which way would you say is the best way to set parameter?
    Greetings!
