Dear all
In the past, few days ago :=) with my HC2 I used these commands lines
/api/callAction?deviceID=28&name=turnOn  and
http://ADMIN:[email protected]/api/sceneControl?id=10&action=start
The first one, to activate a device, is works fine with HC3, no problem
The second, to execute a scene doesn't work with the HC3
Please, could you give me the new command line for HC3 to execute a scene
Thanks in advance
20 answers to this question
As i said before ;) try with
POST Method
/api/scenes/YOUR_SCENE_ID/execute
and in the body: {} if no arguments to pass
You can see the API using swagger from the HC3 interface
    Thanks I will try
    On 3/8/2020 at 1:37 PM, eric78 said:
    Thanks I will try
    did you find the correct api?
    Tried that, the first part seems to work. When entering this in a browser, a page opens, asking for a login and password. After filling in the required part, nothing happens. Not sure if the password was correct or not :), just a white page. Scene did not execute.
    Can you give a hint what input and what dividers are expected? Swagger was not clear on that ;)
    Thanks!
    On 3/15/2020 at 1:32 PM, morpheus75 said:
    On 3/8/2020 at 2:37 PM, eric78 said:
    Thanks I will try
    POST Method
    Thanks!
    Requires POST method, you do not do that directly in browser. Tub can achieve this directly with swagger or postman or others...
    do not forget to pass the body ;)
    How would I pass the body?
    I'm using HA Bridge.
    Sorted! - In HA BRidge you have to add the elements under the respective heading and i have got scenes to work.
    Edited by morpheus75
    Updated
    On 3/24/2020 at 9:55 PM, Krikroff said:
    POST Method
    Thanks for your reply. With homecenter 2 it was as simple as just passing an URL (via POST) to execute a scene. Now in HC3 it doesn't wordt. How can i achieve something tat was simple at first, but seems hard now? A guide or steps would help a lot? I'm not a programmer or someone who is building websites all day and this way it is somehow a search and find game ;) . Apparently there are a lot of people who find this easy? Thanks!
    On 3/8/2020 at 10:53 AM, eric78 said:
    Dear all
    Thanks in advance
    Couldn't get it to work either. As a work around i created a quick app (binary switch or something else) that can be triggered from devices :). You can create a scene with the created quick app as trigger. Don't forget to switch your binary switch back to off, i didn't have the toggle option to choose from. I didn't test a normal switch yet, maybe that gives the toggle option so you don't have to switch the device off again.
    Hours spent in troubleshooting and it was up to me only .... wrong device looking to a wrong IP :)
    But this worked for me to trigger the API:
        self.http:request("http://127.0.0.1/api/service/backups", {
            options = {
                data = json.encode(requestBody),
                method = "PUT",
            success = function(response)
                self:debug(response.status)
                self:debug(response.data)
            end,
            error = function(message)
                self:debug("error:", message)
    Edited by moltos
    Edited by MH8
    POST Method
    I tried to turn on and turn off a light with both swagger and with the curl commandline on my laptop but it takes 30 seconds before the light changes.
    Is this the way it works or can I speed up things somehow?
    30 seconds is not acceptable ;)
    We agree on that :P
    Any hints on where to start troubleshooting?
    I have only 4-6% CPU load and 39% free RAM
    Have you the problem when you turn on/off from HC UI or from mobile app ?
    No. Fast as a shark. Instant control
    ME STUPID! ?
    I didn´t look carefully on the code in swagger
    "delay": 30 ?
    With "delay": 0 there is no delay :P
    That’s my next question ? for sure it’s ok with 0 delay ?
    Hello
    Where can I find HC3 LITE API SWAGGER?
    Thanks,
    G.
    Do you mean a manual?
    Hi All
    I have used the above commands to operate scenes and devices via a URL call and all works OK - except
    Every time I issue a URL call via Edge Browser on Windows it opens a browser window with what appears to be Java code (not sure about that)
        "endTimestampMillis": 1715211160212,
        "id": 0,
        "jsonrpc": "2.0",
        "result": {
            "result": 0
        "startTimestampMillis": 1715211160203
    This is annoying as this window has to be closed manually
    Is there a parameter that can be inserted on the api command line to close this window or a separate command to close that window
    that the api command opened
    Regards Ro
