In making the transfer from HC2 to HC3 based on a cloud backup (update 4.581 Beta) it is stated that "scenes will not be moved and need to be created again". That's OK, but it would be helpful when planning the transfer to know what the differences are (in syntax and available functions) between the two LUA versions. I know that the new LUA editor is documented in https://manuals.fibaro.com/home-center-3-lua-scenes/ . What I would hope to see in addition, is a side by side comparison of all the crucial differences, to enable a pre-edit of the old LUA scenes before entering them into the new editor. Something like this:
If you used this in HC2 LUA: You need to do this in HC3 LUA:
fibaro.debug("txt") fibaro.debug("tag", "txt")
os.time() ???
etc.
If we all contribute to such a table as we identify all the differences, we may be able to help each other prepare for HC3. Not all differences can easily be summarized in the simple two-column format above, however. For the new definition of conditions and triggers, it seems it would be more appropriate to give a few examples of old codes (with triggers) converted to new codes.
PS: I haven't even decided to buy the HC3 yet! But getting a feel for the amount of re-programming needed to convert my scene is an important factor in making that decision.
The suggested table is now shown in a pdf file attached to this post, see below. It is regularly updated as new contributions are posted.
On the HC3 there is only one instance running. They skipped the multiple instance model that was used in the HC2.
A HC3 running instance either block a new scene or the new scene kills the runnin
Yeah, I'd like to add that on HC3 Fibaro works on an "alpha" version internally, then publishes that "alpha" to a group of end-users for feedback.
At the moment, I am not 100% sure if the
First version of summary table, including some that are not mentioned above. I am sure there is more, please post your contribution once you find other differences.
The trigger section is still e
knuth 26
os.time() ???
etc.
LUA HC2 vs HC3.pdf
Edited by knuthMoved summary table to first post
Link to post
10
8
May 12
13
May 25
12
Mar 23
9
Mar 10
5
jgab 19 posts
jjacques68 10 posts
knuth 8 posts
May 12 2020
May 25 2020
Mar 23 2020
Mar 10 2020
jgab
On the HC3 there is only one instance running. They skipped the multiple instance model that was used in the HC2. A HC3 running instance either block a new scene or the new scene kills the runnin
petergebruers
Yeah, I'd like to add that on HC3 Fibaro works on an "alpha" version internally, then publishes that "alpha" to a group of end-users for feedback. At the moment, I am not 100% sure if the
knuth
First version of summary table, including some that are not mentioned above. I am sure there is more, please post your contribution once you find other differences. The trigger section is still e
68 answers to this question
