In making the transfer from HC2 to HC3 based on a cloud backup (update 4.581 Beta) it is stated that "scenes will not be moved and need to be created again". That's OK, but it would be helpful when planning the transfer to know what the differences are (in syntax and available functions) between the two LUA versions. I know that the new LUA editor is documented in
 . What I would hope to see in addition, is a side by side comparison of all the crucial differences, to enable a pre-edit of the old LUA scenes before entering them into the new editor. Something like this:
If you used this in HC2 LUA:                You need to do this in HC3 LUA:
fibaro.debug("txt")                                   fibaro.debug("tag", "txt")
os.time()                                                   ???
etc.
If we all contribute to such a table as we identify all the differences, we may be able to help each other prepare for HC3. Not all differences can easily be summarized in the simple two-column format above, however. For the new definition of conditions and triggers, it seems it would be more appropriate to give a few examples of old codes (with triggers) converted to new codes.
PS: I haven't even decided to buy the HC3 yet! But getting a feel for the amount of re-programming needed to convert my scene is an important factor in making that decision.
The suggested table is now shown in a pdf file attached to this post, see below. It is regularly updated as new contributions are posted.
Edited by knuth
Moved summary table to first post
On 5/25/2020 at 10:50 PM, jgab said:
You do something similar like the /refreshStates loop in my first example. That way you get all events in the system. You can filter out the ones you are not interested in.
it's works perfektly !!!!
but I must create some filters because there is to much informations !
And it can create some problems...
I continue to reflect with filters... ?
Thanks for the idea !!
So I created a simple list of device to filter events.
It works fine.
I check RefreshStates every 200 ms :)
So now, I have a QA to do this, ok.
Can I create another QA to check also RefreshStates, but for something else, like my problems with PIR trigger ?
It's not too much ? 2 questioning ?
It works fine.
If you used code similar to my example it will poll every 200ms, but if there are no events it will hang in the request which kind of pauses the loop so t's pretty ok.
Yes, you can have more than one QA that polls /refreshStates.
Another approach is that you have one QA that polls /refreshStates and then call the other QAs with something like
fibaro.call(<otherQA>,"newEvent",event)
and the other QAs have declared a function to receive the event
The only trick is to decide which types of events should be sent to which QA.
I made a QA some time ago that does something like this
Yes I understand.
One QA to poll and many QA to do the actions...
And Why not with Parent/Child QA ;)
I did it.
One QA to check changes in RefreshStates, and many QA to do actions.
For Ligths with PIR, it's works fine.
I don't miss event any more :)
But I note a small latency (~= 1 seconde) when PIR value is TRUE and lights is ON.
I didn't have this with PIR as trigger of scene...
It's acceptable but... too bad...
On 3/23/2020 at 8:54 AM, jgab said:
HC2:
fibaro:isSceneEnabled(sceneID)
fibaro:setSceneEnabled(sceneID , enabled)
fibaro:getSceneRunConfig(sceneID)
fibaro:setSceneRunConfig(sceneID ,runConfig)
HC3:
function fibaro.isSceneEnabled(sceneID) return api.get("scenes/"..sceneID).enabled end
function fibaro.setSceneEnabled(sceneID,enabled) return api.put("scenes/"..sceneID,{enabled=enabled}) end
function getSceneRunConfig(sceneID) return api.get("scenes/"..sceneID).mode end
function setSceneRunConfig(sceneID,runConfig) return api.put("scenes/"..sceneID,{mode=runConfig}) end -- mode is 'automatic' or 'manual'
Hi everyone. I am looking to get a scene status with this function, but it always returns a "nil" value ? What am I doing wrong ?
Any help would be much appreciated :)
 Sorry, the path in the api.get should start with a "/".
Like
EXCELLENT )) Thanks a lot for your (very) quick help :)
On 3/11/2020 at 2:56 AM, cag014 said:
Please add
HC2
fibaro:startScene(id,{args})
HC3
fibaro.scene("execute",{id,id})
no arguments anymore
This did not work form me.  I had to convert a block scene to lua to find that the syntax is
fibaro.scene ('execute',{[1] = id})
Which makes sense as it kept giving the error "Table expected".
With which command can I find out which profile is active
Edited by parip69
hello, perhaps a very basic question
how do we get the ID of the current scene running
i tried:
Quote
local __sceneId = fibaro.getDevicesID
fibaro.debug("test", __sceneId)
but the result is not the sceneID
[11.10.2024] [15:01:37] [DEBUG] [TEST]: function: 0xffff1c0acaf0
to follow this topic
You could do something like this:
local debug_TAG = "Garage light ID:" ..sceneId -- Tag for the debug messages
fibaro.debug(debug_TAG"some text overhere")
thanks it's working
but just to report
Quote
fibaro.debug(sceneId, "some text overhere")
return an error
[SCENE318]: (load):2: Assertion failed: Expected string
and
Quote
local debug_TAG = "" ..sceneId -- Tag for the debug messages
return no error
i have something that don't understand
i try to modify LUA HC2 to in LUA scene HC3 and i get some trouble
i 'm using in a  function the order fibaro.set/getGlobalVariable but i don't find the contents in the general/variable
even more i don't find the contents with LUA
sequence
the log show the contents
      fibaro.debug("zwave_monitor", "isGlobal: setDefault : gName: " .. gName .. " gData: " .. gData)
[11.10.2024] [18:03:20] [DEBUG] [ZWAVE_MONITOR]: isGlobal: setDefault : gName: zwave_318 gData: {"nackDev":0,"nackNum":0,"inUse":false,"sTotal":0,"deadBuffer":"","sampleEndTime":1728662600,"total":0,"devNum":0,"rptDev":0,"rptNum":0,"sampleStartTime":1728662600,"topDev":{"zAvg":0,"zMax":0,"sTotal":0,"zMin":1728662600,"inTotal":0,"sId":0,"total":0,"id":0,"inId":0},"sample":[{"sum":0,"total":0,"cpu2":0,"cpu1":0,"lRate":1,"lTime":1728662580,"sTotal":0,"dead":""}]}
i set the contents
       fibaro.setGlobalVariable(gName, gData)
one line after
in the same function
i  get the value of the same GlobalVariable
       fibaro.debug("zwave_monitor", "isGlobal: fibaro.getGlobalVariable(gName) " .. fibaro.getGlobalVariable(gName))
[ZWAVE_MONITOR]: isGlobal: fibaro.getGlobalVariable(gName)
but the contents is blank ??
do i miss something ?
sequence
i set the contents
one line after
i find the problem :
we need to create the variable before by hand directly in général/variables , before using the LUA
when the variable is already created then everything went OK
