Climate Zone control from QA
I have several zones which is turned off from time to time. This can be a couple of days and it can be weeks.
On HC2 I have a VD with buttons which set the thermostat to off/heating
In HC3 Scenes I can see the below but these do not work in QA, any suggestion what to use? (And also what us the last nil in the arguments?second last is temperature..)
fibaro.homeCenter.climate.setClimateZoneToManualMode(9, 'Off',"Hold", nil, nil)
fibaro.homeCenter.climate.setClimateZoneToScheduleMode(9)
6 answers to this question
Did you find any answer. I can't find the solution.
Look for panels/climate in swagger.
I have tried all the variables shown in the Swagger. It doesn't work.
I think it is not allowed to set your zone to manual mode from the API.
This is the code, that was written according to variables shown in Swagger.
If you chage the Plan from Scheduled to Manual only 2 relevant variables are changing in swagger.
The "handSetpointheating" and the "mode".
But for some reason, if you try to change these variables in a API call like above, it has no effect. Plan doesnt change to Manual at all.
So this remains for me still a mistery..How can a user change the temperature on his radiator from the YUBII..no only for x hours, but permanently.? The short answer is NOT POSSIBLE...
With the handMode propertie of the climate api you can set it in manual mode and set temperature and timer for the manual mode.
With "mode": "Off" you can set it to Off.
Here how I used it in a scene but should also work in QA.
/monthly_2022_02/image.png.053f4483c37045e741117c5071d4b341.png" />
The api properties mode from the climate panel doesn't support the state "Manual"
The mode of the climate schedule is a different state then the mode you can set in het properties.
Aaaargh, that's insane, I've spent many hours figuring this out but - if anyone needs it - this is how you can do it using the api, works in HC3 in QuickApps:
    local climate_id = 12
    local climate=api.get("/panels/climate/" .. climate_id)
    climate.properties.handSetPointHeating = 22
    climate.properties.handSetPointCooling = 70 --needs to be bigger than Heating value
    climate.properties.handTimestamp = 4294967295   --forever, but you can put the unix epoch timestamp for example in 2h from now, so it will go back to schedule
    climate.properties.currentSetpointTimeStartHour = null --these need to be nulled, otherwise it just won't work
    climate.properties.currentSetpointTimeEndHour = null
    climate.properties.currentSetpointTimeStartMinute = null
    climate.properties.currentSetpointTimeEndMinute = null
    climate.mode = "Manual"
    --self:debug(json.encode(climate)) --in case you want to see the json ;-)
    api.put("/panels/climate/" .. climate_id, climate)
Edited by yoozef
Hello, this code stopped working a few weeks ago, do have the same problem? Do you know, how to repair it?
Thank you very much.
