I have set a variable for a QuickApp in the web interface. Now I want to retrieve that variable with self:getVariable("varname")
It return nil however. How come? What am I doing wrong?
There is an issue with QA variables.
You need at least one time to set variable using self:setVAriable("varname","value")
after that it will work
Edited by cag014
never saw that "bug", can't replicate. Can you give me example? Empty QA, with
directly in init work. No isses as well when i use it in on button clicked.
Create  a new QA variable using UI.
Go to QA:init and try to getVariable (the new one). You'll receive nil
it very rear, but it happened to me...
Edited by cag014
it's just you, not a bug. Just wait till green box is gone ...
Green box? When you define and save new variable, QA executed automatically (It doesn't wait for any green box).
Edited by cag014
and right here the message Comes, if not, you have another problem (or maybe we talk at cross purposes?)
Quote
when you wrote your Code and saved it - sure, will get executed, when you have not added the variable yet, sure Nil will be there, when you go to variables and add - and click on save - and green popus confirms it - Code will get executed and variable value will get displayed.
Edited by tinman
    Strangely enough it works now! The thing that might have happened is that I had to do a reboot due to the whole system being hung. After the reboot the variables worked. Same bug that @cag014  had on occasions?
    Anyhow, thanks for your responses. I am new to Fibaro and just received my HC3 a little over a week ago...
