Aeotec garage door controller
Aeotec garage door controller does not work with Hc-3 it writes partially configured.
I have used garage controller with Hc-2 and worked it.
Edited by oanamattias
7 answers to this question
I have the same problem, anyone have a solution ?
Bought a HC3 to replace my smartthings and its not possible as most of my zwave (zigbee not supported yet) do not work or have template issues. Cant see HUE in app or work with them, same for Logitech and worst of all my Arlo security system is not supported. Should have done more homework, Total waste of good money. Can'r even get Aeotec garage door working. Thought Fibaro was meant to be the best zwave system in the world. Love to meet the person who published that. Very upsetting
    I have sent template for the Aeotec garage door controller to fibaro but I think it doesn't matter
    Hi!
    my garage door controller reports the status configured. The integration itself went without problems.
    I can open the gate via web interface. Closing does not work.
    The status of the gate is detected correctly.
    Have any of you had the same experience?
    Apparently this device was not considered during development. It does not appear in the APP either.
    Best
    /monthly_2020_09/image.png.89609dbba96d5016e9f907621add3380.png" />
    Hello @oanamattias
    for my experience, “not configured” happened when you try to add device with long distance to controller.
    Aeotec and Qubino very demanding products to be added within 1 meter from Home Center
    Try this solution - it will work in 99.9% cases
    I have the same problem, is there a fix or workaround available?
    Looking for an answer and found your post tonight -
     - Hopefully this will work for me.
    Guest Digital_T
    This kind of worked- this will create an app that let you control the doors but gives no status.
    Best would be if Fibaro actually fixed the template(s) and make people happy again.
