I have bought 5 smoke detectors and connected them to my Eneco Toon (Z-Wave).
One of the detectors drains the battery within 2 weeks. It does not matter where I locate the detector. And it's strange that only one does it.
Is there a solution??? Settings???
4 answers to this question
Did you check that the batterie is empthy or is is it only the signalisation ot the sensor?
Maybe it got something wrong when it was included in the network.
Try removing it from the network and then including it again.
    I've connected it to the network twice.
    And changed to new battery 3 times.
    Edited by jackberk
    You can read also my  post about this subject.
    Probally you included the smoke sensor and as default is showed door/window sensor?
    In that case I excuded and included till it showed smoke sensor>>>that resolved my battery problem.
    Succes
