HC3 Dimmer 2 - how to steer S1 button?
I have a lamp connected to the dimmer 2 as in below diagram no.4:
/monthly_2020_03/install3.png.9c605df5ce3b7cfaf5466b84b5e94422.png" />
Additionally the lamp is steering by a motion sensor.
I have 2 questions:
1) How to disable the possibility of turning off the lamp by clicking the button S1 when the lamp was turned on by the motion sensor? (a scene with the trigger on sceneActivationEvent == 11 for dimmer is not working correctly - first the light is turned off and then the code of the scene is executed)
2) How to detect in LUA the way in which S1 button was clicked (I mean by which action - one click, double click etc.)? How to check the "sceneActivationEvent" of S1 in action part of LUA scene?
Thx in advance.
I have 2 questions:
Thx in advance.
Hi Dont think you can S1 is alway leading you woud have to take another input relais switch or smart implant as input for dimmer so you can block the input in the scene .
