Help with HC3 lua
hTiger1
Hi
I control my district heating with Fibaro, it worked well with HCL.
The water temperature in the radiators is controlled by the outside temperature.
But I will try to make an even better system with HC3.
My house is equipped with a "1 string system" - there is very little cooling of the water in this type of system. The greater the cooling in the radiators, the greater the need for heat, which is why I want to send warmer water to the radiators and vice versa.
See the picture of the luascene.
I have 2 temperature sensors:
ForwardFlow = id 90
ReturnFlow = id 91
and
1 valve for regulating water temperature:
FJVvalve = id 166
Here I need help with a very simple lua scene.
The scene on the picture needs to be changed as below
If id91 minus id90 <2.2
then fibaro.call (166, 'setValue', 55)
Thanks in advance for help, maybe I'll need some more help later.
7 answers to this question
You need to set conditions that every value change on ID(91) and ID(90) will trigger the scene. Then in scene you can read values of these devices and do what ever you need.
  • Thanks cag014 @
    Still need to get started with HC3 LUA.
    I don't know how to write the simple line,
    If you can write it for me, it will help me a lot with new scenes.
    Set  in conditions :
    Actions
    Since I don't have such devices, hope it works
  • Thanks
    I want to test it.
  • You got me started with HC3 lua, thanks.
    The declaration section worked perfectly, the action section did not work, but I have mixed something from the Fibaro manuals and your proposal, so now it works perfectly.
    I have made it with 2 output values.
    Can I get 3 outputs in the same scene?
    What do you mean by that?
    Hi @hTiger1,
    as many as you like :-D
    Enjoy coding :-)
