Hc3 + Heat controllers + Schedule
I have an issue with a schedule and heat controllers. When a schedule (in a climate section) is set, everything works fine. However when I will change the temperature for a specific zone in a fibaro home center app, I can see those changes in the climate section but there is an error. It says that not all devices are able to work correctly. It's not possible to control climate zones manually?
I had already complained in the last version, was not fixed yet, I hope for the next update
This issue is fixed in next update.
That's what they said about the update on this version, let's hope that Corona doesn't postpone the update for half a year, although in summer I don't need heating
