Velux KLF200 integration in HC3
JanoS.
15 answers to this question
I have window blind with KUX 100 and now I'm planning to order KLF 200 to have it controlled through HC3 so would be good to know if it works.
I'm using the KLF200 Api with home assistant since not available on hc3. the implementation is awesome if you want to control more than 6 velux devices.
Edited by MasterB
No available QuickApp for now, as HC3 does not support SSL over a tcp connection, which is required to establish a connection with KLF-200.
No news from Fibaro about when this will be available.
For now, the easiest solution is to go through Home Assistant.
Well, i have a working solution. You only need a rpi4 or other machine to run a small script.
Then with some small code, you can integrate the KLF into the HC3.
Sounds great.
I know it's been a while.
Could you share some information on that solution? :-)
I have a rpi4 and HC3 in my system...
38 minutes ago, Danni said:
Sounds great.
Hey Danni,
It seemed that the solution i worked out, was not that fantastic. It worked, but not stable.
Every few weeks, the connection dropped. And i had to restart the KLF. So not really usable.
I am doing it totally different now. I migrated all the stuff i use the rpi for to dockers on a synology nas.
That NAS now also is hosting a HomeAssistant instance. The KLF integration for Homeassistant works
flawless. You could integrate the homeassistant routines into the HC3. But for my usercase its not needed.
So, maybe try it that way :) Sorry to disapoint you.
I'm playing with KLF200 integration to HC3 -
in Lua it works:
but in HC3 it doesn't work
Error is in waitForResponseFunctionVelux:
waitForResponseFunctionVelux - error: Operation canceled
What I don't know exactly - how to correctly re-write for HC3
1.  mode='client'
2. protocol='tlsv1_2'
3. replacing: ssl in ssl.wrap(sock, params) -- maybe it's somehow cover in net.TCPSocket in tls param
4. replacing: peer:dohandshake()   -- I don't know what this command does
I hope that somebody from Fibaro can help. 😀
Edited by petrkl12
@petrkl12 Great! I cant help you with that error, but if later on you need some additional testing i can do that.
Edited by ppeterr
