  • 2
HC3 and MQTT in QA
Guest kallecux
Guest kallecux
Hello! - Happy Easter!
I try to play with the new MQTT-functionality in QA's, but im am not successful.
There i have a MQTT broker on Hassio and this code on HC3:
When i save the QA i get this message on HC3:
[13.04.2020] [13:33:33] [DEBUG] [QUICKAPP353]: onConnected: {"sessionPresent":false,"returnCode":0}
The Broker says this:
1586777612: New connection from 192.168.3.116 on port 1883.
[INFO] found hc3 on Home Assistant
1586777613: New client connected from 192.168.3.116 as randomjdtfpexjvy (p2, c0, k0, u'hc3')
So i think everything is OK, but i get no:
- onSubscribeMessage when the QA started
- onPublished Message when i toggle the switch
Is there anybody who can give me a hint?
Thanks in advance.
Karl Heinz
Edited:
When i toggle the QA Switch, the message is transferred to the broker and the other clients (NodeRed-Cient), but the function onPublished is NOT called!
I think the callback / envent is not executed, so i can not get the subscribed data. :-(
Edited by kallecux
I have a problem now with receiving the values of the lamp.
If I manually enter a value, for example 20,  both sliders with the ID's Brightness and Hue are going to this value.
But when I want to try to do this automatically then only the first in the row are working:
This is the same with the print command, I see only the value of the first in the row.
I'm convinced there's a way to get this right, but I can't figure it out.
Edited by Firepeet
Sorry for the quick response from my side, but is there someone who can kick me to the right way?
My brains are exploded? ?
What value range is payload.hue ?
Sliders usually takes 0-99
38 minutes ago, Firepeet said:
Value range of hue is 0 - 359. I know that i have to devide the value with 3.59.
self:updateView("Color","max","359")
Thanks, but this doen't solve my problem.
The strange thing is that only the top line of tostring(payload....) works.
With the 2 codes below only Dimming works with the top one, and with the bottom one only Color works.
[23.06.2022] [15:26:04] [DEBUG] [QUICKAPP203]: Received message: {"state":"ON","brightness":0,"color_temp":370,"bulb_mode":"white","color":{"r":255,"g":255,"b":255}}
[23.06.2022] [15:26:04] [DEBUG] [QUICKAPP203]: Received message: {"state":"OFF","mode":0,"bulb_mode":"scene","color":{"r":255,"g":255,"b":255}}
[23.06.2022] [15:26:20] [DEBUG] [QUICKAPP203]: Received message: {"hue":120}
[23.06.2022] [15:26:20] [DEBUG] [QUICKAPP203]: Received message: {"state":"ON","brightness":232,"bulb_mode":"color","color":{"r":0,"g":255,"b":0}}
[23.06.2022] [15:26:28] [DEBUG] [QUICKAPP203]: Received message: {"brightness":46}
[23.06.2022] [15:26:29] [DEBUG] [QUICKAPP203]: Received message: {"state":"ON","brightness":46,"bulb_mode":"color","color":{"r":0,"g":255,"b":0}}
Edited by Firepeet
add console information
The bug as described
is still not fixed.
All updateView commands are not working in the UI of the code editor. They are working only correctly outside the editor.
But it's still strange that tostrings(payload.xxx) commands are stop working when they have a calculation in it. For example tostring((payload.hue)*3.59).
The line with the calculation are working, but all other updateView lines below that one are not.
is still not fixed.
You can't set the slider value to a decimal value.
That doesn't apply in my situation. It concerns variable values that come in via an external remote control.
Ok, but tostring((payload.hue)*3.59) *always* works if payload.hue has a number value.
Show us some code with debug statements that does otherwise...
Here the full code.
after I turned on the lamp, I first operated the color slider. This one works.  But the Brightness slider doesn't work after that.
When I switch those 2 lines, brightness works and color doesn't.
Debug:
[25.06.2022] [11:44:55] [DEBUG] [QUICKAPP203]: 1 on
[25.06.2022] [11:44:55] [DEBUG] [QUICKAPP203]: Received message: {"state":"ON"}
[25.06.2022] [11:44:56] [DEBUG] [QUICKAPP203]: Received message: {"state":"ON","brightness":97,"color_temp":205,"bulb_mode":"white","color":{"r":255,"g":255,"b":255}}
[25.06.2022] [11:45:03] [TRACE] [QUICKAPP203]: UIEvent: {"elementName":"Color","deviceId":203,"values":[58],"eventType":"onChanged"}
[25.06.2022] [11:45:03] [DEBUG] [QUICKAPP203]: Colorvalue : 58
[25.06.2022] [11:45:04] [DEBUG] [QUICKAPP203]: Received message: {"hue":58}
[25.06.2022] [11:45:04] [DEBUG] [QUICKAPP203]: payload_hue: 58
[25.06.2022] [11:45:04] [DEBUG] [QUICKAPP203]: Received message: {"state":"ON","brightness":217,"bulb_mode":"color","color":{"r":255,"g":253,"b":196}}
[25.06.2022] [11:45:12] [TRACE] [QUICKAPP203]: UIEvent: {"elementName":"Dimming","deviceId":203,"values":[45],"eventType":"onChanged"}
[25.06.2022] [11:45:12] [DEBUG] [QUICKAPP203]: Brigntnessvalue : 45
[25.06.2022] [11:45:12] [DEBUG] [QUICKAPP203]: Received message: {"brightness":46}
[25.06.2022] [11:45:13] [DEBUG] [QUICKAPP203]: Received message: {"state":"ON","brightness":46,"bulb_mode":"color","color":{"r":255,"g":253,"b":196}}
[25.06.2022] [11:49:18] [TRACE] [QUICKAPP203]: UIEvent: {"elementName":"button_1_off","deviceId":203,"values":[null],"eventType":"onReleased"}
[25.06.2022] [11:49:18] [DEBUG] [QUICKAPP203]: 1 off
[25.06.2022] [11:49:18] [DEBUG] [QUICKAPP203]: Received message: {"state":"OFF"}
[25.06.2022] [11:49:19] [DEBUG] [QUICKAPP203]: Received message: {"state":"OFF","brightness":46,"bulb_mode":"color","color":{"r":255,"g":253,"b":196}}
Ok, there are some issues....
First, I don't see the debug messages you have in the code. I see 'Received message:' but not the self:debug('payload_hue
later in your QuickApp:myCallBack.
Have you edited the log?
Secondly
will update the slider with a numeric value - you need to convert the whole value to a string
etc.
and why
twice?
Then, have you adjusted the max values of the sliders - seems like values can be > 99 now.
Finally, beware when updating a slider with a value that doesn't arrive with the message - like kelvin
Secondly
etc.
and why
twice?
The log is not edited. This is the debug of payload_hue:
Thanks, this solved some issues:
Kelvin is the ID of the Temperature / Saturation slider.
This slider has 2 functions. If color is selected, this slider will be set the saturation value. If white is selected, the temperature value will be set with this one.
Whitevalue is responsible for this. value 1 is white, value 0 is color. Maybe it's better that I put an IF THEN  ELSE for both self:updateView("Kelvin" rows.
Anyway, I'm a little further ahead. Huge thanks for this??
