New HC3 on its way: Do I Migrate my HC2 via the transfer process or setup everything from new?
I am sure many people are asking what are the pro's and con#'s of each route:
Migrating Pros - Known:
Sections, rooms and icons will be migrated
Z-Wave devices assigned to the rooms and their icons
parameters of these devices
Cameras not created via plugins
associations
Migration Con's - Won't be transferred
Scenes
plugins
virtual devices
cameras via plugins
schedules (watering & climate)
Questions:
If a device is transferred, does HC3 tell the device to use 500 series communications automatically and will HC2 put the device in secure mode? (All my Heating Controllers (Fibaro Thermostats) are not in secure mode as you cannot upgrade if they are in secure mode
Can I force Secure mode of a device that is transferred or do I have to remove it and re-add it to enable secure mode?
Are my LUA scenes compatible (Cut and Paste [Changing deviceid as needed] from HC2 to HC3)?
What are the other Pro's and Con's people have seen?
BusterB1959 7
Questions:
Any pit-falls to watch out for?
Link to post
4 answers to this question
