I want to migrate this plugin from HC2 to HC3. How I can edit a VFIB file without HC2? Any tool?
It’s difficult to change the code?
thanks!
4 answers to this question
The Fibaro's function in LUA have changed in HC3. Everything has to be checked and corrected in the codes.
Moreover, if you don't have any knowledge in LUA, it will be very hard.
But, you can wait for the HC3 version of the
. Maybe Krikroff may add this option in the HC3 version. Nothing is sure!
You can directly ask for this function in the dedicated topic :)
    Thank you,
    Yes, probably it's very hard for me. I try to see the code of this plugin and i don't understand nothing... hahaha
    Thanks you, i try to put this feature in the topic ?
    I’m interested too to add yeelight lamps to FIBARO home Center 3. I ‘ve just upgraded from a dump xiaomi mi home gateway to FIBARO hc3 and so far got 5 dimmer2 modules, but have 6 lamps from my old setup that I would like to add.
    Yeelight Bedside lamp 2 x2
    Yeelight colour bulb x2
    Yeelight strip light x2
    Does anyone have any updates on how to connect Yeelight bulbs with HC3?
    Edited by Rafal100
