Fibaro HC 3 with Somfy remote control
pblacky
How can i learn a somfy 433 mhz remote control to my new fibaro HC3 ?
I tried to find a suitable device in the "other devices". Unfortunately there is nothing from Somfy there!
any hints ?
6 answers to this question
  • On the website of the
    there is an entry under Interfaces that shows 433 mHz.
    is that wrong ?
    Continuing with the same question, and what is indicated in this Web in German https://intuitech.de/ufaqs/unterschied-der-fibaro-gateways/ under the connection between 433MHz, it was planned to have the connection supported with Fibaro HC3 by Q2 2020. Currently we are in Q2 2021.
    Is there any news about it?
    Thank you very much for any feedback provided
    Let me join the discussion and correct a few things:
    HC3 as well as Yubii have a 433MHz radio.
    The Somfy protocol is protected by patents and we need official approval for implementation. Unfortunately Somfy refused us some time ago so we should not expect any integration with Somfy
    Official integration with Somfy protocol is available via Somfy devices
    How it works I can't answer because I haven't tested the devices
    @A.Socha, when last time I asked Somfy about Z-Wave interfaces, then they told me they do not have any for Europe market. They have certified product for Europe, but they use it in China. Maybe Velux for io-homecontrol (i know it is not RTS) would be interested to work with Fibaro on official plugin for their KLF 200.
    Workarround for getting RTS to Fibaro would be integrating whole Tahoma controller (
    ) or their RS485RTS (
    ), which I did on HC2, but that was just open, close and stop and no feedback, but I do not know if RTS has feedback. Regarding RS485RTS, its serial number is needed for integration.
