gedein1785 2
Hi ,
Anybody that could clarify/help on following
my current config config : HC2 fw 4.580
univ sensor with 2 inputs detected; a scene is triggered if 1 one the inputs are tripped (works fine)
5 X fibaro flush switches , 2 inputs managing 3 lights ; a scene manages these and other lights
2 ea fibaro flush dimmers , working in association
2 flush dimmers working autonomous
1 smoke sensor fibaro; based on other comments i don't dare to put in the network
1 additional smoke semsor POPP 4001 : works perfect ; one can command the sirene and is a part of a scene
now : I want to add a "smart implant " to detect a trigger from an alarm panel ,
Purpose is to sound the POPP sirene ( see above) when fire or smoke is detected .
The alarm panel sends its output using OC outputs ; Vcc is 12v; configuration set to "N.O" (i can change)
Smart Implant has a Vcc of 12V
configuration of Smart Implant:
input 2: Binary sensor, smoke alarm. active when NO ( see above)
incident becoming a problem:
whatever the output of the alarmpanel is (0v or 12V ) the value notified at the Smart Implant stays "0" ( using a small scene in a loop to retrieve the "value")
Anybody an idea?
Is the 12V at IN2 too high and sets the read value to 0 ? ( see other posts on the input used as analog input)
Or is the Smart implant defective?
txs
Geert
4 answers to this question
