Viewing Z-Wave connection matrix from HC3
Zitzer
Is there a way to view Z-Wave connection matrix (which device is able to connect with which device) from HC3?
but i am using www server.
Thanks 10den@,
My MAC still refuse to show the network regardless of Safari or Chrome.
When using Windows 10 and IE ( on a PC ) is OK.
As it is a static picture, that's OK.
Dann
My MacBook randomly shows the diagram. I can't figure out what triggers it showing up. I use SimpleHTTPServer.
My iPhone and iPad also shows the diagram sometimes when I open the link to my simple server on the Mac.
Sometimes it takes a while before the digram shows up...
For Chrome, use the extension "Web Server for Chrome", link to the folder with files and you can view the matrix.
4 hours ago, mhomefibarovn said:
Hi @10der
It is great tool.
But I can't load this web site. Can you support it.
Pls check this image. (window 11, chrome)
hi-hi :) lol
Hello, as much as I try, it stays in .... Loading, they could help me, it's important to me, I have about 90 devices on 3 floors and it doesn't work very smoothly and I need to see that it's failing.
The only reliable diagnostic is a Zniffer.
If you search the forum about zniffer you get a lot of information about diagnostics and trouble shouting.
You need Zniffer. Please start reading here, and thank user @alex88 for writing this, and @tinman for posting the instructions to "build" a Zniffer
On 12/29/2021 at 2:06 PM, mhomefibarovn said:
Hi @10der
It is great tool.
This Error happen with you because you open file to browser direct there is must be server to open from browse if you use VS code install (live server) extension
then open from it or download any server application on your windows
You also able to run locally with these steps:
1- Install Node js - https://nodejs.org/en/
2- go to folder where you have html file:
                      - In CMD, run the command to install http server- npm install http-server -g
                      - To load file in the browser run - http-server
3- If you have specific html file. Run following command in CMD.- http-server fileName
4- by default port is 8080
5- Go to your browser and type localhost:8080. Your Application should run there.
6- If you want to run on different port: http-server fileName -p 9000
Edited by ABDULLAH258
Works great, but only in Firefox portable (im using this FF for Hisense NVR, live preview) Thanks for that!
Edited by Pavel Bohac
It seems to display incorrectly in my case, probably because  my setup has several controllers in master slave configuration.
In any case it was useful since the devices.json contains the last updated time that is actualy the one value I was looking for beter control the health of the zwave nodes in my overall system,
since from time to time  devices show  ok but stoped reporting either by no batery, by gateway connection inestability, no contact, and I only discover it once an automation behaves incorrectly.
I actualy miss / was unable to find something basic like this in current HC3.
