RING doorbell
public beta V2
/monthly_2020_06/image.png.32049e2d2fdba33453cff15cc54a5d75.png" />
scene for motion / ding -> screenshot
Edited by 10der
  • Like 3
    10 hours ago, Kvamme86 said:
    What model of the ring doorbell ?
    support any models.
    i am owner old model -
    /monthly_2020_05/image.png.8ac55028291968584423ccd2b2104b95.png" />Ring Video Doorbell Pro
    How is the Ring connected?
    EDIT, never mind, found it.
    Edited by rvelthoen
    for starting device (once) we should ask OTP token
    please press the button
    /monthly_2020_05/image.png.0f5670d82b985f0e00454f84c60c2bcb.png" />
    if all is ok (login and password - is OK)
    you can find in variabled a new var with name OTP
    simple edit and key OTP what you should get via SMS (or email)
    do not forget press SAVE button.
    device will re-started and hook this OTP.
    if all is OK this var should be also empty like "-"
    and you can see label OK
    and in Variables you can see two new vars
    please DO NOT remove this vars, cuz device use this var for accessing and refreshing "ring" session.
    on "motion" device simple change value as usual binary device on the "ring" event device also change value true but also send the custom event
    "ringdoorbell" and you can hook this event for action when smb ringing on your doorbell.
    snapshot in dev process.
    /monthly_2020_05/image.png.e9a48cc568f70b237a2d1c29a2ff9b11.png" />
    I will annonce when will it work properly.
    and sorry no camera support cuz fibaro doen`t have methods for showing images locally from variable.
    UPD:
    now
    customEvents/ringdoorbell
    sending on motion and ding evenets
    if you want to know  what kind is please read userDescription
    local events = json.decode(fibaro.getValue(fibaro.getDevicesID({name="Ring doorbell"})[1], "userDescription"))
    json store
    1) action - ding or motion
    2) img - base64 encoded image. you can may send this image via tellegram
    /monthly_2020_05/image.png.1624f9c66fdd71754630ffb369322c56.png" />
    here is method for adv users:
    Will it work with HC2?
    I'm thinking about buying this device becouse it's work on Samsung TV QE75Q9FNA.
    public beta V2
    drop it.
    proprietary piece of ... :) with closed API and controlling accesing to ring clouds plus you can ban for 1 day if something is not good from ring,com perspective
    PS: yes can works on any adnroid TV but with gapps. but you cant config popup when smb ring or mothion the door. for example
    I have own plugin for XBMC for this....
    • 1 month later...
    I was able to buy a new one (ring doorbell pro)  for 100EU at a good price. At the moment I'm happy because it works for me with pop-up windows in Alexa show 8 and on Samsung TV qe75q9FN. When I'm watching TV and somebody calls me, a TV window pops up in the upper right corner. The TV has smartthings implemented in it. It works as it was for now.... but in fibaro HC2 no.
    1st have a plan a new version for HC3
    2nd no potrable code to HC2 sorry
    Edited by 10der
    • 2 months later...
    Hi Guys,
    i am getting 401 while requesting for OTP, am i missing something ??
    @SmartTech some APi already changed,
    i 'll update QA.
    now it works like a charm!
    @SmartTech
    Thank you., you are awesome - another clarification, i am using for Stick up cam. is there any settings i will need to change?
    i am not sure here. probably no
    I have entered the OTP and its coming up as "Starting"
    • 4 weeks later...
    Getting this Error: "HTTP error: 400" - Any idea how to fix this?
    • 2 months later...
    @10der
    Hello Oleg, thanks for the great QA. I got it going (I think) If I press the button on the doorbell, I can trigger a scene with it. Your scene above sends a photo to a device ... but what kind of device is that (ID1818)? hank you very much. Greetings Sven
    1st of thank you for using my QA
    2nd I should update this QA - now my QA more stable and i haven't any issues with ring
    3d -
    /monthly_2021_01/image.png.80b7ae74e57f03f493b08c8c2e9acfd6.png" />
