JcBorgs 52
Want to use the Fibaro app to arm and disarm the house. But how do you perform a check in either block or LUA that checks if any of the sensors are in breaching before arming the alarm?
Do want a check that is initiated when the house is arming and if any of the door/windows sensors are open or if there are movement registered at one of the movement sensors the arming should be cancelled and a push message sent saying what sensor is active.
Have tried now both in Block and LUA but can’t get it to work, thought I solved it with a combination of “Armed” sensor and open/movement on the sensor which then disarmed the house, but when testing it out I realized I failed miserably because that scene actually disarmed the house if there was an actual breach later when the house was properly armed.
So open for any suggestion, this is what I want to achieve:
- Arm the house with the Fibaro App.
- If an sensor is open or movement registered when the house is “arming” the arming should be cancelled and a push message sent saying what sensor that was active.
12 answers to this question
