Lights: setlevel but no getlevel?
Why is there an actioname 'setlevel'  to set a new light level to a light, but not a 'getlevel' to get the current level? Or am i missing something?
I want to readout the level before i temporary adjust the level and than reset the original level after some time.
this is wat i see for my light:
"actions": { "abortUpdate": 1, "reconfigure": 0, "reset": 0, "retryUpdate": 1, "setValue": 1, "startLevelDecrease": 0, "startLevelIncrease": 0, "startUpdate": 1, "stopLevelChange": 0, "toggle": 0, "turnOff": 0, "turnOn": 0, "updateFirmware": 1
8 answers to this question
1 minute ago, okidoki said:
Is a ecodim dimmer. And yes  of couse i meant setValue, sorry, my mistake.
Here is the list of actions: I was looking for a getvalue to get the level. I also have quibino mini dimmer, but there is it not available either. I just have work with setvalue. Can do that.
Ok, then you get the value with fibaro.getValue(61,"value")
These are actions that are invoked by fibaro.call(...)
fibaro.call never return any value.
The idea is that fibaro.getValue(<id>,<property>) should be used for that and that the value is a property of the device. I don't know if the 'level' is a property of your device. Have a look with swagger if there is any property that reflects the current level.
    yeah, i'm aware of that. I checked but its not a property of my light devices. So i have to use the setlevel. I'll find a solution.
    Thks for the answer.
    What type of device is it? (what physical device/brand, and what "fibaro type" does it get? ex. "com.fibaro.multilevelSwitch")
    ...and do you have a 'setLevel'? or do you mean 'setValue'?
    hello,
    Having this issue with numerous hue lights, I did it by directly requesting information from the hue Bridge instead of from HC3.
    It's perfectly working and sure to have the latest full information (status, hue, bri, ct, x, y ...)
    can share some code lines if could be a good approach for you
    regards,
    mathias
    Edited by Mateo
    /monthly_2020_05/image.png.bbd89f3589928662fbfb11cfc25cefd2.png" />
    6 hours ago, Mateo said:
    hello,
    regards,
    mathias
    Thks for the offer Mathias, but i don't have any hue lights. Is just a normal dimmable led with some zwave dimmers of ecodim and quibino.
    Ha, It Works!  @jgab Thanks a lot! I tested and the levelvalue is correct. Great!
