knuth
Controlling heating panel
I am trying to get my head around the use of Heating Panels in HC2. I am still a little confused, and need your help. Below, based on some testing, are some statements that I believe to be factual, but they may not be. Please confirm or correct any of them. My main concern is the lack of a way to override zone control of individual thermostats, see three statements in italics
For your reference, I have 13 HeatIt Z-trm2 thermostats, divided into three zones. When referring to apps, I mean the iPhone versions.
General
There are three modes: Schedule, Holiday, and Manual:
·         Schedule mode sets a fixed cycle per zone, based on time of day and day of week
·         Holiday mode sets a fixed temperature per zone, no time limit
·         Manual mode is not really “manual”, but a time-limited override of the time schedule (or of holiday mode) for an entire zone
There is no way to control an individual thermostat manually if it has been included in a zone on the heating panel, regardless of the current mode for the zone. To allow individual adjustments, the thermostat needs to be excluded from the zone. The heating panel may not be deactivated without removing all zones and thermostats.
Using the web interface
Choosing Panel – Heating panel – Manage, the interface allows all operations: set or change holiday mode, define manual mode including set point and duration, define calendar and temperatures for schedule mode. Also used to define zones, and to include/exclude thermostats from these zones.
If an individual thermostat device is adjusted while it is included in a heating panel zone, the thermostat responds, but returns to its mode set-point after “some time”.
Using the wall-mounted thermostat display
Local adjustments of an individual thermostat are reset to the mode value (same as for individual adjustments using the web interface)
Using the old app
Mode may be changed to “manual”, to “holiday”, and to “schedule” (by choosing “turn off”). Holiday and manual mode temperature may be set or changed. The schedule times and temperatures may not be adjusted. Individual thermostat set-points may be adjusted, but are reset to the mode value.
Using the new app
Holiday mode temperature may be read, but not changed. Mode may seemingly be changed to “back to schedule” or “manual”, but the latter is not available starting from holiday mode.  The schedule may not be adjusted.
When modes have changed using other apps or the web interface, the new app does not immediately update its list of modes per zone. Individual thermostat set-points are visible, but may not be changed (regardless of the use of heating panel).
Share this post
Link to post
  • There has been no response to the above summary, which may either indicate that it is accurate or that the topic is not seen as interesting.  I raise the question once again, now that the heating season is getting closer. Any comments from anyone? Any suggestions on how to get around the weaknesses of heating panels?
    Share this post
    Link to post
