QA: Unknown error occurred
[27.05.2020] [22:06:01] [ERROR] [QUICKAPP1639]: Unknown error occurred:
[27.05.2020] [22:07:01] [ERROR] [QUICKAPP1639]: QuickApp crashed
[27.05.2020] [22:07:01] [ERROR] [QUICKAPP1639]: Unknown error occurred:
[27.05.2020] [22:08:01] [ERROR] [QUICKAPP1639]: QuickApp crashed
[27.05.2020] [22:08:01] [ERROR] [QUICKAPP1639]: Unknown error occurred:
[27.05.2020] [22:09:01] [ERROR] [QUICKAPP1639]: QuickApp crashed
[27.05.2020] [22:09:01] [ERROR] [QUICKAPP1639]: Unknown error occurred:
[27.05.2020] [22:10:01] [ERROR] [QUICKAPP1639]: QuickApp crashed
[27.05.2020] [22:10:01] [ERROR] [QUICKAPP1639]: Unknown error occurred:
[27.05.2020] [22:11:01] [ERROR] [QUICKAPP1639]: QuickApp crashed
[27.05.2020] [22:11:01] [ERROR] [QUICKAPP1639]: Unknown error occurred:
UPD: all QA traps
11 answers to this question
    @A.Socha
    question: can too much tracing (for example @KrikroffSonos) QA logs leak or somthing else affects HC3?
    how big is your QA we got in current version bug that is crashing when is bigger then 130 000chars (fixed in next version)
    idk
    tomorrow in office i will install and tell you is it crashing for me too
    btw, works more than 2 weeks... idk what happend today... stars?
    so. 10k. it's < 130k
    @A.Socha
    Oppps!
    i have REMOVE all QA
    now my QA is
    issues stil here!
    ok. for Fibaro it's'not intersting.
    so rebooting..
    /monthly_2020_05/image.png.b68d11a75299dffca695848253766fc5.png" />
    @A.Sochano issues after reboot
    now my QA is
    So yeah only a debug statement in "init" and it still crashes...
    Ah! Have seen that one too.
    I have not reported yet because I cannot reproduce it reliably but I have had it a few times...
    Here is what I think is happening:  I write some kind  of "syntax error" so Lua source is not valid ->  "QuickApp crashed" every minute  -> I fix the error but the quickapp keeps crashing. As soon as that happens, nothing can repair this particular FQA. Even when you make it empty,  ->  "QuickApp crashed" every minute
    So my guess is something goes wrong when HC3 translates the source code internally (it processes the source, there is some "magic" going on with FQA to extract properties from the source). Or somethong does not write the new source code to the database.
    The only way to make such a "stuck" FQA work again is reboot HC3.
    Yes!!! It feels like Peter was in my place!
    Peter, thnak you so much!
    I am not alone!
    I am not alone!
    You  are not alone. Had a variant of the problem again 5 minutes ago, but unfortunately I am not sure what caused it. Only a reboot fixes the problem. I was editing a FQA device, clicked "save" and QuickApp:onInit() did not get called anymore (not even when the device is empty, apart from a single debug statement). I could not keep the crashed state because I am working on your "mqtt disconnect/reconnect" problem, I need to work ;)
    If it happens again, I'll leave the system as is and copy/paste all my code from the crashed FQA Device to a new, empty FQA and report a bug...
