Witam koledzy  . Posiadam na HC 2 odtwarzacz iEast Player i poprzez VD uruchamia mi codziennie radio RMF . Mam pytanie czy próbował ktoś uruchomić iEast na HC3 ? Nie mam pojęcia jak to zrobić W QUICK APPS a Centrala HC2 działa już u mnie tylko po to żeby uruchamiać ieast Player ;/ czyli trochę lipa :( Proszę o pomoc.  Pozdrawiam
5 hours ago, Albert said:
As diferenças na API e nas estruturas de dados retornadas em resposta às chamadas da API podem fazer com que outras marcas não funcionem ou funcionem parcialmente. As funções básicas provavelmente funcionarão. As funções avançadas como configuração Multiroom não funcionarão. A Arylic desenvolve firmwares próprios e, pelo que vejo, a qualidade de suas soluções está acima da iEast e de outros. Seu aplicativo móvel, 4Stream, suporta mais idiomas, inc. Língua polonesa também.
Ok....
Albert@, thanks for the reply, any work on a new version to include multiroom in iEAST for HC3?
I do not plan to develop iEast anymore. No support from them and their devices are not developed and improved as I wish.
When I did a QA for iEast on HC3, I contacted iEast for some support, documentation, API, permission to use graphics. No response, even though I received an email read receipt.
What worked as a multiroom control on HC2 no longer works (today's API version no longer contains the correct views).
I plan to expand the existing QA with a multiroom, but the function will be such that it is first necessary to assign slave streamers under the master via the application. Subsequently, it is only possible to enable / disable for specific slaves. If disabled, content other than the master can be played on the slave.
Due to its functionality, it is definitely not the function I am looking for, because on the contrary, I use it to select music and play, so
and organizing a multiroom / single flat application.
