LUA: if power is > 8 then press vd button X ONCE
I’m trying to write a LUA scene where power value is the trigger. I want that if power is above 8 then press button 2 on VD once. If power is below 7 press button 4 once.
Now when I write a scene like this, everytime there is a power change above 8 watt the button on the VD is pressed. That trips my HC2 and VD.
How can I solve it that the VD button is pressed once when the power is above 8 watt regarding the power value changed above the 8 watt?
5 hours ago, jgab said:
With some hacking you can get it.
'rolling55' will be a variable that rules can trigger on that will contain  the rolling average of the las t5 values of device 55. rigger variables only trigger if the actual value changes too so that's nice.
Could be something to build into future version of ER... could also be over time instead of samples.
Nice. Thank you
