sensibo sky HC3 integration?
Hi everyone
Are there any examples of Sensibo integration?
Also quick app?
13 answers to this question
You should be able to find it on the Fibaro Market Place if you are still looking for it.
    thanks for your advice
    I saw it on the Marketplace just a few weeks ago. But now, just now I need it, it seems to be gone? Anyone knows where the Sensibo QA went?
    disappeared after download
    It is in use, but it seems there are some operating errors.
    From the looks of it they are making revisions to the Quickapp it re-appeared and then disappeared again today
    I got the updated file from them directly, the listing is stuck in "In Review" State.
    hi, i bought a sensibo sky and i'm trying the QA rev.2 on HC3 but i can't figure out which is the sensibo id. can someone help me?
    Hi, only new to but you can make the api key under:
     --> goto the 3 lines left above (the menu) make an api key and for the ID's you can find them in the AC tab under the three "..." under advanced info: UID this is the id.
    Bart
    Oh btw the [dev id] is the fibaro id of the QA, just installed the above sample works great ! Thanks @TechPigeon for posting !
    I have a virtual device for Sensibo on my HC2, but now I'm thinking of upgrading to HC3. How well does the QA work on HC3 for Sensibo Sky now?
    Le 28/07/2021 à 14:59, Bart999 a déclaré:
    Oh au fait, le [dev id] est le fibaro id de l'AQ, je viens d'installer l'échantillon ci-dessus fonctionne très bien ! Merci@TechPigeonpour poster !
    salut
    Pour moi ça fonctionne pas
    Edited by 971jmd
    Looking for a stable version... has this one been stable for you?
